Simon, Airspy #1 at your QTH is inop
Does nothing when trying to operate.
Here's what I copied:
Connecting to 81.174.138.141::50101
Connected
Sending <SVRMsg Command="Radios" Username="Guest" Password="GuestPwd"></SVRMsg>
Reply
XML: <SVRMsg Command="Radios" Defns="&lt;SDRRadio>&lt;RadioDefn Accounts=&quot;&quot; Address=&quot;3652E880ECDC38D3&quot; Bandwidths=&quot;&quot; DllID=&quot;Airspy HF+&quot; Enable=&quot;1&quot; InUse=&quot;1&quot; Model=&quot;Airspy HF+&quot; Options=&quot;Board revision 1&quot; Port=&quot;0&quot; RangeHigh=&quot;250000000&quot; RangeLow=&quot;0&quot; Serial=&quot;3652E880ECDC38D3&quot; Title=&quot;Airspy HF+ #1&quot; VisualGain=&quot;0&quot;/>&lt;RadioDefn Accounts=&quot;&quot; Address=&quot;C852D65DEF3839F7&quot; Bandwidths=&quot;&quot; DllID=&quot;Airspy HF+&quot; Enable=&quot;1&quot; InUse=&quot;1&quot; Model=&quot;Airspy HF+&quot; Options=&quot;Board revision 2&quot; Port=&quot;0&quot; RangeHigh=&quot;250000000&quot; RangeLow=&quot;0&quot; Serial=&quot;C852D65DEF3839F7&quot; Title=&quot;Airspy HF+ #2&quot; VisualGain=&quot;0&quot;/>&lt;RadioDefn Accounts=&quot;&quot; Address=&quot;1721-061C-5345303339355F30303034000000000000000000000000000000000000000000&quot; Bandwidths=&quot;&quot; DllID=&quot;ELAD-FDM-S1LAN&quot; Enable=&quot;1&quot; InUse=&quot;1&quot; Model=&quot;FDM-S2&quot; Options=&quot;&quot; Port=&quot;0&quot; RangeHigh=&quot;160000000&quot; RangeLow=&quot;0&quot; Serial=&quot;SE0395_0004&quot; Title=&quot;FDM-S2&quot; VisualGain=&quot;0&quot;/>&lt;RadioDefn Accounts=&quot;&quot; Address=&quot;USB&quot; Bandwidths=&quot;&quot; DllID=&quot;Microtelecom001&quot; Enable=&quot;1&quot; InUse=&quot;0&quot; Model=&quot;Perseus 1.0&quot; Options=&quot;Hardware = 1.0, Product code = x8014&quot; Port=&quot;0&quot; RangeHigh=&quot;30000000&quot; RangeLow=&quot;0&quot; Serial=&quot;03981-2107-5FAE-3A5E&quot; Title=&quot;Perseus 1.0&quot; VisualGain=&quot;0&quot;/>&lt;/SDRRadio>" Error="Valid"></SVRMsg>
Command: Radios
Status: Valid
Defns: <SDRRadio><RadioDefn Accounts="" Address="3652E880ECDC38D3" Bandwidths="" DllID="Airspy HF+" Enable="1" InUse="1" Model="Airspy HF+" Options="Board revision 1" Port="0" RangeHigh="250000000" RangeLow="0" Serial="3652E880ECDC38D3" Title="Airspy HF+ #1" VisualGain="0"/><RadioDefn Accounts="" Address="C852D65DEF3839F7" Bandwidths="" DllID="Airspy HF+" Enable="1" InUse="1" Model="Airspy HF+" Options="Board revision 2" Port="0" RangeHigh="250000000" RangeLow="0" Serial="C852D65DEF3839F7" Title="Airspy HF+ #2" VisualGain="0"/><RadioDefn Accounts="" Address="1721-061C-5345303339355F30303034000000000000000000000000000000000000000000" Bandwidths="" DllID="ELAD-FDM-S1LAN" Enable="1" InUse="1" Model="FDM-S2" Options="" Port="0" RangeHigh="160000000" RangeLow="0" Serial="SE0395_0004" Title="FDM-S2" VisualGain="0"/><RadioDefn Accounts="" Address="USB" Bandwidths="" DllID="Microtelecom001" Enable="1" InUse="0" Model="Perseus 1.0" Options="Hardware = 1.0, Product code = x8014" Port="0" RangeHigh="30000000" RangeLow="0" Serial="03981-2107-5FAE-3A5E" Title="Perseus 1.0" VisualGain="0"/></SDRRadio>
Count: 4
Connected
Sending <SVRMsg Command="Bandwidth" Model="Airspy HF+" Title="Airspy HF+ #1"></SVRMsg>
Reply
XML: <SVRMsg Command="Bandwidth" Bandwidth="30000,40000,50000,75000,100000" Status="✓"></SVRMsg>
Command: Bandwidth
Status: ✓
Bandwidths: 30000,40000,50000,75000,100000
Closed
Closed
Connected
Sending <SVRMsg Command="Soundcards"></SVRMsg>
Reply
XML: <SVRMsg Command="Soundcards" Soundcard="Line 1 (Virtual Audio Cable)&#09;Microphone Array (Realtek(R) Audio)"></SVRMsg>
Command: Soundcards
Error:
Soundcards: Line 1 (Virtual Audio Cable) Microphone Array (Realtek(R) Audio)
Closed
PS Was trying to see if your SDR's can hear the 17M QRM (OTHR?) on the top end of 17M.
Re: Simon, Airspy #1 at your QTH is inop
Thanks, it's an early pre-release HF+, goes offline at times.
