Multi recording of bands
anilsrk0
Unread post by anilsrk0 »
Hi all,
currently i am using BladeRF 2.0xA4 device on sdr console.. Is it possible to record multiple Bands simultaniously?
If possible please share me the solution..
also is it possbile to add any pluggin for sdr console software?
Re: Multi recording of bands
You can record the whole bandwidth of your radio and use Datafile Editor to pull out any segments from the recording.
You can't make 2 separate recordings at the same time, however.
anilsrk0
thanks goofee for your reply,
i got the solution and by using multiple receivers in console we can record upto 24 channel simultaniuously... but i have two more doubts
1. Is it Possible to perform BAND SCAN(FOR UNKNOWN FREQUENCIES) IN SDR COONSOLE (MEANS MY TUNING BANDWIDTH IS AUTOMATICALLY SELECT SIGNALS) LIKE SDR#
2. DOES SUPPORTS EXTRA PLUGINS IN SDR CONSOLE, IF POSSIBLE PLEASE GIVE THE SOLUTION
1. No, SDRC doesn't have a scanner.
2. No, no option for plugins
regards, Leon
