FT8 on QO-100 with Adalm Pluto impossible
F8DQL
Unread post by F8DQL »
I am trying to do FT8 on QO-100 with an Adalm Pluto SDR, on a 90 cm dish with a Othernet Bullseye LNB which is pretty stable
My Pluto has a GPSDO clock and I use the Geostationary Beacon feature, there is no drift at all.
A virtual audio cable makes the link between WSJT-X and SDR Console V3.2 build 2731.
The waterfall looks good and so does the audio in SDR Console :
WSJT-X seems to get the audio correctly :
However it decodes absolutely nothing.
The same configuration (wsjt-x and virtual audio cable) with a websdr instead of SDR Console works fine, the issue is consequently in my RX chain.
Do you have any idea?
G0SYP
Re: FT8 on QO-100 with Adalm Pluto impossible
Unread post by G0SYP »
You can't see it very well in the screenshot but there may be some drift after all. If you set "N Avg 1" (normally it's N Avg 4 or 5) in the waterfall, you can see it better.
Even small temperature variations can be killers for some modes at 10 GHz.
dg9bfc_sigi
Unread post by dg9bfc_sigi »
ft4 and ft8 run fine here with my tcxo driven pluto and a tcxo driven lnb (plus beacon lock)
dg9bfc sigi
