I am trying to do FT8 on QO-100 with an Adalm Pluto SDR, on a 90 cm dish with a Othernet Bullseye LNB which is pretty stable
My Pluto has a GPSDO clock and I use the Geostationary Beacon feature, there is no drift at all.
A virtual audio cable makes the link between WSJT-X and SDR Console V3.2 build 2731.
The waterfall looks good and so does the audio in SDR Console :
WSJT-X seems to get the audio correctly :
However it decodes absolutely nothing.
The same configuration (wsjt-x and virtual audio cable) with a websdr instead of SDR Console works fine, the issue is consequently in my RX chain.
Do you have any idea?
