FT-897 external radio CAT issue
py2oc
Unread post by py2oc »
Hello.
I'm running an identity for QO-100 that has a SDRplay RSP2 Pro as receiver and an FT-897 as external radio.
When tuning directly from the FT-897, everything works fine and the frequency on SDR Console is changed to the same I handled on the vfo.
When tuning from SDR Console 10Hz is randomly added to final tuned frequency.
Example: tuning to 10.489.520.000 (432.020.000 on external radio) the final frequency on SDRPlay is tuned to 10.489.520.010 (432.020.010 on external radio)
This issue happens only when running FT-897 as external radio. Running other transceiver (TS2000) as external radio, everything is ok.
Is that a possible bug or am I missing something?
73 de PY2OC, Luiz
