Not sure where this should go - but so long as people will read it and tell me what is going wrong.
I am trying to bypass the manual entry into the Scheduler because what I want to set up would take "forever". In am trying to import a csv file directly into the SQLiite database, using SQL Studio.
In brief - I raise a few entries in the Scheduler manually and close SDRConsole. Then in SQLliteStudio I export just the table to CSV, including the header row, using System encoding.
If I then delete those entries in the database and then import them from the csv file created they load without problem. Then I open and start SDRConsole, open the scheduler and the restored database entries are present. The schedules run.
But if I open the csv file and make any changes and import them to the SQLlite dtabase it 'falls over' - usually I can run SDR Console but I get a "program will close" error when I try to open the Scheduler window.
Has anyone successfully imported data into the Scheduler Database from a csv file edited on OpenOffice or Excel?
What I'm trying to do is produce a recording schedule that record a sequence of 5 minute files back to back at different frequencies for FM DXing - eg start at 06:00 on 91 MHz, switch 5 minutes later to 98 MHz, and repeat ad infinitum. (but I have to build in a 5 second gap, so it is actually at 5 min 5 sec intervals, to allow for SDRConsole's switch over time).
David
Help with Scheduler module
Jump to
- SDR-Radio.com
- ↳ Forums
- ↳ Bugs
- ↳ Computer Talk
- ↳ Developer News
- ↳ 💾 Download
- ↳ Kits, Release Notes
- ↳ Requests
- ↳ General Radio Topics
- ↳ SDR Chat
- ↳ Simon's World Map
- Console
- ↳ General
- ↳ V2
- ↳ SDR Television
- ↳ Analyser
- ↳ External Radio
- ↳ Interfacing
- ↳ Satellites
- ↳ Transmit
- ↳ Videos
- Server
- ↳ General
- ↳ Server Status
- Radios
- ↳ Other
- ↳ Afedri
- ↳ Airspy
- ↳ ANAN (hpsdr)
- ↳ Andrus
- ↳ Cross Country Wireless
- ↳ DXpatrol
- ↳ ELAD DUO Transceiver
- ↳ ELAD S1/S2/S3/DUOr
- ↳ Ettus Research
- ↳ hackRF
- ↳ Hermes-Lite 2
- ↳ ICOM r8600
- ↳ Lime Microsystems
- ↳ NUAND
- ↳ Perseus
- ↳ Pluto
- ↳ Red Pitaya/Stemlab
- ↳ RFspace
- ↳ RTL/SDR
- ↳ SDRplay
- ↳ Softrock
- ↳ WiNRADiO
- 3rd Party
- ↳ Other
- ↳ CW Skimmer
- ↳ DSD Plus
- ↳ Frequency Manager Suite
- ↳ go2MONITOR
- ↳ Ham Radio Deluxe
- ↳ MMSSTV, MMRTTY
- ↳ Virtual S-Meter
