SDR Console can't find Air Spy HF+
Douglass Allen
Unread post by Douglass Allen »
I've used Air Spy Mini successfully for years. When I substitute my Air Spy HF+, "Select Radio" only lists the Air Spy Mini which is not plugged in, and doesn't list the Air Spy HF+ which is plugged in. I deleted SDR Console and then downloaded a new version. Same problem as before Help!!!
Doug K4LY
Re: SDR Console can't find Air Spy HF+
Did you build a definition for the Airspy HF+? Each and every SDR that SDRC talks to has to have a unique definition specific to that individual (serial number) SDR.
When upgrading SDRC, the definitions are saved and will work with the next upgraded version, providing you don't uninstall the whole SDRC pkg.
So... build a definition for the AirSpy Mini as well as the Airspy HF+ and all should be well in the kingdom. lol
Purveyor of NUMEROUS Airspy SDR's available via SDRC Server
