RSPdx , after it was sitting around for a month or so unused , i plugged it in and fired up sdrc and the noise floor indicator needle was at a 8 and the s-meter needle was stuck at a S-9 and nothing i did (adjusting rf-gain/if gain) would get them any lower even with no antenna , then i faintly recalled around 3 months ago it happened then , then recalled around 6 months again it happened and then i recalled this method that seemed to reset? the rspdx .
Which was to 1st fire up sdruno after re-plugging in the rspdx and noticed straight away the s-meter sat just below a S-1 with no antenna , then closed sdruno and fired up sdrc and all back to normal with low readings on the s-meter .
This seems to happen if the rspdx is left sitting around not used for awhile and one does not use sdruno 1st , maybe there is some sort of volatile memory? in the rspdx that dissipates and needs sdruno to fill it , who knows but that is the method i used today again and there probably a reason for it so i don't actually know if its a glitch . Paul
I came across this Glitch? again today
- lappydesktop
Jump to
- SDR-Radio.com
- ↳ Forums
- ↳ Bugs
- ↳ Computer Talk
- ↳ Developer News
- ↳ 💾 Download
- ↳ Kits, Release Notes
- ↳ Requests
- ↳ General Radio Topics
- ↳ SDR Chat
- ↳ Simon's World Map
- Console
- ↳ General
- ↳ V2
- ↳ SDR Television
- ↳ Analyser
- ↳ External Radio
- ↳ Interfacing
- ↳ Satellites
- ↳ Transmit
- ↳ Videos
- Server
- ↳ General
- ↳ Server Status
- Radios
- ↳ Other
- ↳ Afedri
- ↳ Airspy
- ↳ ANAN (hpsdr)
- ↳ Andrus
- ↳ Cross Country Wireless
- ↳ DXpatrol
- ↳ ELAD DUO Transceiver
- ↳ ELAD S1/S2/S3/DUOr
- ↳ Ettus Research
- ↳ hackRF
- ↳ Hermes-Lite 2
- ↳ ICOM r8600
- ↳ Lime Microsystems
- ↳ NUAND
- ↳ Perseus
- ↳ Pluto
- ↳ Red Pitaya/Stemlab
- ↳ RFspace
- ↳ RTL/SDR
- ↳ SDRplay
- ↳ Softrock
- ↳ WiNRADiO
- 3rd Party
- ↳ Other
- ↳ CW Skimmer
- ↳ DSD Plus
- ↳ Frequency Manager Suite
- ↳ go2MONITOR
- ↳ Ham Radio Deluxe
- ↳ MMSSTV, MMRTTY
- ↳ Virtual S-Meter
