As your probably aware? MMSSTV has been updated a bit into the 21st century by some EA's over there in Espania , the latest version is 1.13.3 and is on the EA's website http://radiogalena.es/yoniq/ and use a translator , YoniQ does have some quirks still .
The YoniQ mode is propriety to this version above and the previous v1.13.2 and has its own mode button .
The YoniQ mode is around 3 seconds slower than scottie 2 which 71 seconds for a 320x256 so is around 75 seconds also with a much slower scan/sync rate (about half) than scottie 2.
The YoniQ mode can only be decoded by another Yoniq! otherwise it just looks like a smear of colours .
Now onto the quick test we did last night on 40m , distance around 1200klm , the band a bit crashy/staticy both ends , sigs around S8 both ends and fairly steady , same goes for the Noise .
These are the RX pictures i received
1st is YoniQ then Scottie 2 look at the time which is the last 4 numbers in UTC , IE:1026 utc
3, 4 , 5 are YoniQ , then Scottie 2 , then Scottie 1 being the last one
Cheers Paul VK4AGK
MMSSTV and the new YoniQ Mode
- lappydesktop
- 202307071026.jpg (45.16 KiB) Viewed 27390 times
- 202307071025.jpg (45.42 KiB) Viewed 27390 times
- 202307071014.jpg (28.68 KiB) Viewed 27390 times
- 202307071012.jpg (28.58 KiB) Viewed 27390 times
- 202307071010.jpg (43.28 KiB) Viewed 27390 times
