Crossed out speaker symbol for mutet recifers
hurz_66
Unread post by hurz_66 »
Crossed out speaker symbol for mutet recifers right inside the recifer pane would be useful , too.
3rd request in a row, neverthenless thanks for ur work! :-)
Re: Crossed out speaker symbol for mutet recifers
hurz_66 wrote: Thu Oct 26, 2023 5:57 pm Crossed out speaker symbol for mutet recifers right inside the recifer pane would be useful , too.
If you are using Squelch then there is a yellow speaker symbol that shows when that receiver is "un-squelched".
Receiver mute status is already shown in the Receiver tab:
However, yes, I agree. I think it would be good to have a permanent "muted/unmuted" status indicator on the RX windows.
hurz_66
I know, as with the volume slide in each rx... :-)
I have mentioned this to Simon on the Test Team (mute speaker symbol). Let's see what happens.
Volume, I doubt this will be added. For volume another possible solution (for a few receivers) is to take each RX out via a separate VAC to audio mixer like Voicemeeter Potato:
https://vb-audio.com/Voicemeeter/potato.htm
Not quite what you wanted I know, but just a suggestion.
hurz_66
Ok, thanks
