Repost from Groups.io -- Simons World Map bearing gauge
KK7PW
Post by KK7PW »
From Feb 21 -- just found this forum and thought to share here as well. Simply an idea. :)
Simon,
Not sure if this is the place to post ideas for World Map, but I am wondering if it would be possible to add a small bearing gauge to the rotor control function similar to what was in HRD. Would really be a help as a quick-glance tool. And maybe a double-click function on the actual dial to activate turns to bearing?
Thanks for any thoughts.
73.
Jonathan, KK7PW
Re: Repost from Groups.io -- Simons World Map bearing gauge
Post by KA1GJU »
Both Long Path and Short Path are visible on the World Map by turning them on by hoing to the "Home Tab", and clicking the appropriate path to be shown in the "Settings" tab. I believe you press the 'Shift' key and click on a location on the map to move the rotor. I'm not using that feature, but thats what is says on the "Rotor" tab in the "Help" window.
YMMV
