Virtual Cable problem with 3.3
m0ppr
Unread post by m0ppr »
Hi All, I apologise if I don't provide too much info. Equipment: Pluto. I had SDR Console 3.2 + Virtual cable working with FT8, once installed 3.3 it stopped working. The WSJT was unable to activate TX correctly. If I increased audio level coming thru virtual cable, TX got activated but it stayed transmitting forever. Downgraded to 3.2 and everything is working fine again.
Re: Virtual Cable problem with 3.3
m0ppr wrote: Sun Dec 31, 2023 11:41 am Hi All, I apologise if I don't provide too much info. Equipment: Pluto. I had SDR Console 3.2 + Virtual cable working with FT8, once installed 3.3 it stopped working. The WSJT was unable to activate TX correctly. If I increased audio level coming thru virtual cable, TX got activated but it stayed transmitting forever. Downgraded to 3.2 and everything is working fine again.
There really should be no difference. How are you triggering TX - VOX? Maybe add a screenshot so I can see the VOX settings, gain may have to be reduced.
