V3.3 Issue
DL1NM
V3.3 Issue
Unread post by DL1NM »
For me and another radio amateur friend, the sensitivity in the display dropped drastically after installing 3.3. Where previously S9+5 were at the top of the upper QO-100 beacon, I only saw S3.
We had installed the new version over the old one 3.2, so the settings should be the same, right?
What are we doing wrong and what should be done?
73 DL1NM, Gerd
Re: V3.3 Issue
Screenshots using the "screenshot" button with the DSP panel and radio settings displayed would be most helpful.
Do not place them in the text, but attach them (full editor must be enabled, below the text box).
Installing updates are placed over the current version, so you are correct, settings "should" be the same.
Re: V3.3 Issue
DL1NM wrote: Wed Feb 28, 2024 12:44 pm For me and another radio amateur friend, the sensitivity in the display dropped drastically after installing 3.3. Where previously S9+5 were at the top of the upper QO-100 beacon, I only saw S3.
73 DL1NM, Gerd
Gerd, what is the hardware? Pluto, Lime?
72
Re: V3.3 Issue
One might also ask, "Has the readability of any of the incoming signals changed?"
DL1NM
Re: V3.3 Issue
Max wrote: Wed Feb 28, 2024 8:23 pm
73 DL1NM, Gerd
72
NESDR
DL1NM
Re: V3.3 Issue
jdow wrote: Thu Feb 29, 2024 12:44 am One might also ask, "Has the readability of any of the incoming signals changed?"
Nope. It concerned mostly the beacons of QO-100. (Another sporadic signals as well)
Falling back to V 3.2 the issue was gone.
DL1NM
Re: V3.3 Issue
KA1GJU wrote: Wed Feb 28, 2024 8:01 pm Screenshots using the "screenshot" button with the DSP panel and radio settings displayed would be most helpful.
In the next days I will start with 3.3 again "from the beginning". At the moment I run 3.2 and thus it doesn't make sense to post a current screenshot .
Re: V3.3 Issue
DL1NM wrote: Fri Mar 01, 2024 3:18 pm
The reason I asked if Pluto or Lime is that in 3.3 some recent changes were made to Visual Gain calibration in the Lime. Be interesting to know what hardware you are running?
DL1NM
Re: V3.3 Issue
@Max
See #5
Re: V3.3 Issue
So what are you using as the sampler plugin to SDRC? "#5" is not an answer. (It also sounds, from what I've read, that you are expecting readings that are unrealistically high. And, no, sometimes there are changes to the apparent "calibration" of the uncalibrated non-instrument colloquially called SDRC.
