Console V3.3 SDRPlay rsp1b
HughP
Unread post by HughP »
I have down loaded Consol V3.3 and installed on Win 10 64 bit.
I have also installed the API (3.15 from SDRPLAY) and can see during the installation that the driver was shown for the RSP1B. I purchased the RSP1B a couple of days ago, new.
In Console I try to open a definition. SDRPlay is in the list but it just has V2 and V3.
RPS1B is plugged in.
I have SDR Connect up and running so I must be missing something when installing Console.
I would like to use Console as I know I can slow the waterfall down as needed for meteor detection.
Have unistalled and reloaded but still the same result.
Any ideas?
Hugh M0ACF
Re: Console V3.3 SDRPlay rsp1b
HughP wrote: Fri May 17, 2024 6:55 pm
Any ideas?
Hugh M0ACF
This is correct. V3 and V2 refer to the API version. Just select V3. It will then say SDR Play API running (or some such). Press "OK".
It then says "1 device found". Press "Add". Then press "Save".
Job done.
HughP
Thank-you for the reply Max. I will try it later today. Hugh.
HughP
Thanks Max, reinstalled Console and the API (3.15) and found my RSP1B under SDR PLAY - V3.
All up and running.
73's Hugh
HughP wrote: Sat May 18, 2024 10:51 am Thanks Max, reinstalled Console and the API (3.15) and found my RSP1B under SDR PLAY - V3.
All up and running.
73's Hugh
NP Hugh. Glad you got it running.
