Memory Feature Request
JLMetcalfe
Unread post by JLMetcalfe »
I'd like to see memory channels, when chosen, to be highlighted just like the frequencies in the receive pane. The receive pane frequencies have a light blue appearance when active.
Re: Memory Feature Request
JLMetcalfe wrote: Wed Jun 26, 2024 6:27 pm I'd like to see memory channels, when chosen, to be highlighted just like the frequencies in the receive pane. The receive pane frequencies have a light blue appearance when active.
Just for clarity, I think you mean the active RX in the Ribbon Bar Receive Tab, not the Receiver Pane.
Not sure how the logic works for the memories? With multiple receivers, you'd need to keep track of what the last memory selected by which receiver, then "decolour" it as soon as even the smallest adjustment was made, on a "per receiver" basis? What purpose would it serve? Not saying it has no purpose, I just don't understand what is to be gained and how to make it give any additional useful information to what is available already?
If the purpose is to identify a particular station is selected, this is better served with Markers:
https://www.sdr-radio.com/markers
JLMetcalfe
Max wrote: Wed Jun 26, 2024 9:35 pm
Yes, whatever you call it. When I open "Receive" I see the active frequency highlighted in light blue. With "Memories" I'd like to see the same. If you've got 40 memory channels, a highlighted frequency would be very easy to identify. It might not be logical, but it's just what I notice, based on the way I use the software.
Thanks for the reply, Max.
