Output power slider
dg3feh
Output power slider
Unread post by dg3feh »
Hej!
The Output power slider shows values ​​between 0 and 100%. unfortunately this regulator is not linear with the output power. Is it possible to linearize this or even calibrate it in dBm or W?
73, Holger DG3FEH
Re: Output power slider
Yes and no. It can be linearized if your amplifier is linearized more. It cannot be calibrated. It adjusts the level of the signal by multiplying each sample by a number between 0 and 1.0. So it's not even dB related. (That would actually be silly unless you are designing an instrument rather than a communications device.)
