3.4 beta and Yaesu FTdx5000
OH1KT
Unread post by OH1KT »
Hi. I had installed the 3.4Beta version of the console on my own computer and my intention was to use it as a PAN adapter together with a Yaesu FTdx5000 radio. My SDR receiver is a FunCube pro+. The signal is controlled from the IF connector of the radio and the Yaesu radio is connected to the console using Omnirig 1.2 version. For some reason the console cannot synchronize data with the radio at all even though all the settings are correct. When I changed the console to the previous version 3.2 everything works as it should. I have not yet tried to get HamRadioDeluxe to work together with the radio and the console, at least in that Beta version I could not get it to work and I have not yet had time to test whether HRD works with that 3.2 version. The HamRadioDeluxe program also has the ability to connect it to third-party programs using the DDE function, but I do not know if this method also works with the SDR console.
73 Ilkka OH1KT
Re: 3.4 beta and Yaesu FTdx5000
Duplicate.
OH1KT
I thought it would probably be a good idea to put that problem under the Bug heading as well, it probably wouldn't hurt :)
