IC-R8600 settings for SDR-console
pe2bz
Unread post by pe2bz »
when adding the IC-R8600 to SDR-console (v 3.4) I noticed that both converter selection and invert spectrum where enabled.
I disabled both before saving, but does the spectrum has to be inverted when using the R8600 or is this something which is kept as setting from another radio which have been added ?
Ben
Re: IC-R8600 settings for SDR-console
Check what is said on SDR-Radio.com. Follow the menus. If the spectrum works correctly with invert spectrum ticked, then leave it ticked for the IC-R8600 definition. The radio is also a converter. So leave that on unless the help for the radio indicates otherwise. If you get spectrum inverted wrong then USB signals will be wrong and frequencies that should appear to the left of center will appear right of center.
