in the following groups.io discussion it was already asked about flip mode implementation for better rotor control.
https://sdr-radio.groups.io/g/main/topi ... p/31264782
I now wanted to put this feature request in the correct location.
The gist is as follows.
For rotors supporting 180° of elevation rotation, one can track a satellite in two ways.
This is handy to avoid running into the end stops.
Say for example we have a satellite that rises at 340°N and sets at 30°N
Then, if our rotor system's end-stop is in the south, we do not have a problem. We can set our elevation to 0° and azimut to 340° and normally track it.
But if the end-stop would be in the north we would have a problem with the above approach. Because we cannot pass over 360°.
So the approach would be to use flip mode, start with our elevation at 180°, point the antenna in the other direction, and set the azimut to 340°-180=160°.
Now as the pass progresses we can somethly follow and avoid the endstop in the north by rotating over the south.
So to implement this we would need two options:
- A checkbox to enable and disable Flip mode, because not all rotor systems support it.
- A input box to input where our endstop is located.
Then the logic would need to compute where a pass crosses the endstop and in that case, do the above adjustments so long as flip mode is enabled.
So the new elevation would be 180° - original
And the new azimut would be original - 180°
Thank you for your help
73 de
Benjamin HB9HIH
Correct implementation of rotor endstops and Flip mode
Jump to
- SDR-Radio.com
- ↳ Forums
- ↳ Bugs
- ↳ Computer Talk
- ↳ Developer News
- ↳ 💾 Download
- ↳ Kits, Release Notes
- ↳ Requests
- ↳ General Radio Topics
- ↳ SDR Chat
- ↳ Simon's World Map
- Console
- ↳ General
- ↳ V2
- ↳ SDR Television
- ↳ Analyser
- ↳ External Radio
- ↳ Interfacing
- ↳ Satellites
- ↳ Transmit
- ↳ Videos
- Server
- ↳ General
- ↳ Server Status
- Radios
- ↳ Other
- ↳ Afedri
- ↳ Airspy
- ↳ ANAN (hpsdr)
- ↳ Andrus
- ↳ Cross Country Wireless
- ↳ DXpatrol
- ↳ ELAD DUO Transceiver
- ↳ ELAD S1/S2/S3/DUOr
- ↳ Ettus Research
- ↳ hackRF
- ↳ Hermes-Lite 2
- ↳ ICOM r8600
- ↳ Lime Microsystems
- ↳ NUAND
- ↳ Perseus
- ↳ Pluto
- ↳ Red Pitaya/Stemlab
- ↳ RFspace
- ↳ RTL/SDR
- ↳ SDRplay
- ↳ Softrock
- ↳ WiNRADiO
- 3rd Party
- ↳ Other
- ↳ CW Skimmer
- ↳ DSD Plus
- ↳ Frequency Manager Suite
- ↳ go2MONITOR
- ↳ Ham Radio Deluxe
- ↳ MMSSTV, MMRTTY
- ↳ Virtual S-Meter
