noelec sdr with sdr console v3
Cookric555
Unread post by Cookric555 »
hello im having trouble with my nooelec sdr working with sdr console v3 the definitions are there but when i press play nothing happens it only happens with sdr console v3
Re: noelec sdr with sdr console v3
Did you read the following:
sdramateur
Unread post by sdramateur »
Cookric555 wrote: Thu Oct 15, 2020 11:58 am hello im having trouble with my nooelec sdr working with sdr console v3 the definitions are there but when i press play nothing happens it only happens with sdr console v3
I have the same problem.
How did you solve it?
Cookric555, what brand of nothing do you mean? Does it run and not show any data?
Showing full size picture of SDRC running and perhaps of the definitions panel might help. More data means more help, usually. It helps experienced users notice settings that are significantly different from what they use themselves.
They work fine here and have for a very long time.
edit: My nooelec dongle is in critical use so I cannot address that specific brand. I do have some other testable dongles.
