Using RX whilst recording
pnoelw
Unread post by pnoelw »
Is it possible to set the IQ recorder and continue to use a receiver without the recorder modifying its centre frequency?
Last night I set the recording session centred on 440kHz with a BW of 500kHz and ticked the Lock Radio Frequency box and hit start. I then changed the RX1 frequency to 518kHz to monitor Navtex. The recording was then centred on 518kHz with a BW of 500kHz.
Is there a way to set the recording and still move the RX frequency without affecting the recording?
Re: Using RX whilst recording
Lock frequency is selected by default.
If you clicked it you may have disabled it?
pnoelw
Thanks for the reply, Jim. I had ticked the Lock Frequency box.
I've just had another look. I now understand that you can tune the receiver and provided you don't centre it or change the visible span then all remains as set in the recorder.
