Hello Simon,
there are a lot of new SDRs with high bandwiths now and comming.
But as they use a huge bandwidth the lack of band-filtering and without filters they will be exposed to high summing signals and maybe suffer from intermodulation.
It is fine to have a broad spectrum visible but to have good reception of DX-signals in a dedicated band the receiver should have a preselector/bandfilters.
I work with Heinz Stampfl, HB9KOC, on an external preselector for the Shortwave bands.
He has a nice version WaveStar with 8 bands up to 30 MC/s prepared in kit-form which will be available by funkamateur.de soon.
I prepared the firmware for this preselector; the problem was that Heinz had the hardware ready before I could do the programming.
But I was able to program the ELAD-interface used between ELAD-SDRs an the ELAD-preselctors (SPF-08) which uses a simple SPI with a shift register in the preselector.
With ELAD it works fine and now I made an additional ARDUINO-interface to combine it with SDR-Console using CAT.
So the WaveStar will work with SDR-Console and with the interface also the ELAD-SPF-08 will work with SDR-Console and other than ELAD-SDRs.
But I think the way using CAT is not very fine.
I have to poll the active receiver 1 to 2 times a second...
It would be nice to have an definition-table in SDR-Console similar to that used in ELAD-SW2.
Here you can define frequenzy ranges for the control of the individual filters in the preselector.
Especially using the SFE-interface-table (each band uses full 8 bit for adressing) which is much better than that for SPF-08 (only 8 bands, using a 1-of-8-bit-code).
That means a definition-table with bandstart, bandend and the filter-number.
When the RX-frequency goes in the range of a band the filternumber should be send as a serial-data (on COM: and with USB-serial-interface to the preselector).
Could also be a ASCII-sequence like a CAT-command.
That would be a very versatile interface for each possible preselector (the preselector equipped with an Arduino to switch the filters in which way it is ever needed, as serial communication or with a parallel 8-bit word...).
With the new ELAD FDM-S3 (and also with ELAD FDM-DuoR) it is not possible to use the SPI-interface with the ExtIO-socket as those units use internal filters.
As best preselectors would have to use more than the possible 8 (or even 7 plus the bypass-board) a CAT-interface comming from the software would be versatile.
What do you think of that idea?
Any change to realize that in future?
vy 73, Ernst, DL2EBV
Preselector control
OnlineSimon G4ELI
Re: Preselector control
A good idea, I assume the command is an ASCII string?
I can honestly say that spending a few days coding this doesn't really get me very enthused at the moment
