1.0.18 Dec 23rd 2020 - Space Weather
Space Weather
  • As requested, the space weather window size is now continuously adjustable over a greater range.
Kit
1.0.18
G3ZQH
Re: 1.0.18 Dec 23rd 2020 - Space Weather
Unread post by G3ZQH »
Thanks Simon. I can see the size adjustment slider but it does not change the space weather window size on my PC. It reverts to the central default setting each time even if I drag it to another position. As it happens, the default text size is readable in my small map window so it sort of works for me. Hopefully a small tweak will get this going as expected.
73 Dave G3ZQH
G3ZQH wrote: Wed Dec 23, 2020 11:56 am Thanks Simon. I can see the size adjustment slider but it does not change the space weather window size on my PC. It reverts to the central default setting each time even if I drag it to another position. As it happens, the default text size is readable in my small map window so it sort of works for me. Hopefully a small tweak will get this going as expected.
73 Dave G3ZQH
It'll not work if the ribbon bar is floating, a bug in the ribbon bar code, otherwise it works fine here.
G3ZQH
That's it! I have it working now. I just reset the 'customise' settings in the toolbar and that seemed to fix it.
Excellent- many thanks Simon.
73 Dave G3ZQH
