- As requested, the space weather window size is now continuously adjustable over a greater range.
Kit
1.0.18
It'll not work if the ribbon bar is floating, a bug in the ribbon bar code, otherwise it works fine here.G3ZQH wrote: Wed Dec 23, 2020 11:56 am Thanks Simon. I can see the size adjustment slider but it does not change the space weather window size on my PC. It reverts to the central default setting each time even if I drag it to another position. As it happens, the default text size is readable in my small map window so it sort of works for me. Hopefully a small tweak will get this going as expected.
73 Dave G3ZQH
