Monitor Audio Output
Sam
Unread post by Sam »
Hi
I use a Hermes Lite and virtual audio cable to transfer audio to a 3rd party applications (WSJT-X).
It would be nice to be able to monitor the audio being transferred for the change in band conditions etc, however i've not found a way to do this unless i change the audio playback output from VAC to speakers and then back again.
Is there any other way to solve this?
Would it be possible to add a monitor output button in the software?
mbott
Re: Monitor Audio Output
Unread post by mbott »
In the Control Panel, be sure and set the VAC Properties to Listen to this Device.
Mike
Or are you looking for this? ...
KI4BEA
Unread post by KI4BEA »
How do I get to the above window? I can not find it.
KI4BEA
Never mind. Found it.
Sam
@mbott Thanks that worked!
@PD3LK I've now tried that window, Speakers selected and RX button checked, however i cannot get any sound. Any more suggestions what setting may be wrong?
Off the wall suggestion... Tools->Options->Auto-Mute turned on?
Sam
Thanks jdow
It was turned on, turned it off, however it didn't change the situation.
I'll keep looking out for something else.
Sam, there is some confusion here. Suggestion by PD3LK is principally to monitor TX audio.
mbott offered one correct solution. It's actually what I do myself. I only ever have SDRC RX audio out permanently set to VAC whether I am using the VAC or not, and then always have "listen" checked as he shows and fed to speakers. Never change it. I then always know that VAC 1 is my RX line out to third party progs at all times.
VAC 2 back from WSJT-X to TX in.
VAC 3 permanently allocated to CW skimmer (must be dedicated only to CWS)
If you have the original VAC from Eugene (Evgenii) Muzychenko ( https://vac.muzychenko.net/en/index.htm ) he also provides a companion program called Audio Repeater to achieve a similar result for monitoring the output of the VAC:
https://vac.muzychenko.net/en/repeater.htm
This also works very well.
Sam, I should have clarified, suggestion from PD3LK........ (the TX monitor panel).
That panel is for monitoring your TX audio input, nothing to do with RX audio. When the TX button is enabled, the TX audio input is monitored, but only when in Transmit mode. With the RX button pressed, your TX audio input can be monitored when SDRC is in RX mode without need to be in TX mode. It's for checking audio input quality, most likely via headphones rather than speaker (to avoid audio feedback). For most normal purposes both the buttons would be selected OFF during normal operation, unless you want to monitor your audio when in TX on FT8 for example. More useful for initial setting up of the audio quality from the mic for SSB etc.
Hope it helps.
