Low sensitivity with Airspy HF+
VK7OO
Unread post by VK7OO »
I am using a Airspy HF+ with a remote server on my LAN. If I use SDR-Console server the receiver sensitivity is significantly lower than it should be. Using the same radio with Spyserver, the sensitivity is as expected. For this comparison all the hardware is the same and the client software is SDR-Console 3.0.26.
Are there XML settings for the SDR-Console Server that can adjust the sensitivity?
cheers
de VK7OO Steve
Re: Low sensitivity with Airspy HF+
Screen shots of radio settings would be most helpful.
Many settings which effect sensitivity under SDRC, does Spyserver have the same? Never used it, so not familiar with what’s available to the user.
VK7OO
Thanks Chris
I may have a problem elsewhere, so my original post is probably misleading.
thanks
Steve VK7OO
