Hi Simon, next to the few adaptions that are already asked for or reported (Ingwolf), i would like to suggest adding a edit button in the Scheduler. In many cases we make repetitive recordings and only need to change date or time. Editing works much faster then copy a rule, edit it and then delete the old one.
Other thingy, when a recording is running and the user overrules Lock Radio and changes the frequency, then - in the recording - the stations appear on wrong frequenties. Maybe someone has a good reason not to do this but why not stop a recording as soon as someone unlocks the radio? In my view that recording is otherwise worthless anyway.
Data scheduler
Re: Data scheduler
Hi Leon and all.
I do concur with your suggestion. An edit feature would be nice.
I often do mistakes when doing a repetitive task several times and have to delete the incorrect one and create a new. Edit would be a great help.
Of cause, the dream would be to be able to set-up the whole nights recordings in one shot. To specify start time, duration, repetition interval and stop time and voila you have a set of recordings created!
Keep on dreaming
The recording feature is very good to have. Very useful.
73 / Ingolf, SM6FHZ
Keep on dreaming
73 / Ingolf, SM6FHZ
Re: Data scheduler
I'm busy next week with the Winradio G31DDC, remind me in a week or so, these are (mainly) good suggestions. I was thinking about a repeat function - Ingolf nailed the idea!
Re: Data scheduler
Just having the option in the current scheduler set up to ignore dates and just use the times would make it much more useful. I like to move up and down in frequency, recording 5 minute blocks.sm6fhz wrote: Sat Feb 06, 2021 9:11 pm
Keep on dreaming
73 / Ingolf, SM6FHZ
