Transmit enable
G8VLR
Transmit enable
Unread post by G8VLR »
Hi All, I have a Lime mini sdr and although I can receive perfectly well, all transmit options are greyed out. Am I missing something obvious? I'm running 3.0.27 2123.
Regards,
Roger.
Re: Transmit enable
Lime mini has problems that have led to Simon seeming to loathe them and lock out transmit on them.
G8VLR
Re: Transmit enable
Ah, okay, thanks jdow. I'll have to try sdrangel although you need a physics degree to use it :-)
Re: Transmit enable
Should be called SDRDevil.
G8VLR
Re: Transmit enable
It can transmit! Just needed to set the bandwidth to 750KHz (tx). It now transmits with Sdrconsole!
Chuffed!
Roger.
