Maximum hold indefinitely in Spectrum Display?
Joerg
Unread post by Joerg »
First off, congratulations to the author(s) for an amazing piece of software. I am just exploring it after using SDR# for a while with various SDRs.
So here is my question: With the View->Maximum button I enable the yellow maximum curve in the spectrum display. How can I change the timeout for the max curve to indefinitely? I use that feature all the time in SDR# to find transient signals in the displayed spectrum over an extended period of time.
Thanks much for any pointers!
Re: Maximum hold indefinitely in Spectrum Display?
Joerg wrote: Tue Feb 20, 2024 9:23 pm So here is my question: With the View->Maximum button I enable the yellow maximum curve in the spectrum display. How can I change the timeout for the max curve to indefinitely? I use that feature all the time in SDR# to find transient signals in the displayed spectrum over an extended period of time.
Hi Joerg. As nobody else has answered, AFAIK the persistence of this feature cannot be changed in any user settings. I think people looking for transients would do this by doing a data recording and analysing the data playback later? How, I'm not sure. I know you can skip quickly through a data playback in presetable "chunks" (see attached image).
https://www.sdr-radio.com/data-recording
Joerg
Hi Max, thank you for the reply. Without going into too much detail, I often scan good size chunks of the spectrum for transient signals that may only occur very infrequently. Once I identify frequencies of interest I analyze the signal further. For the latter the playbeck is a huge help. But going through hours or even days worth of data using the replay would be very cumbersome. I am hoping that a future release may include a variable timeout for the max line, up to indefinitely. IMO it should be fairly easy to implement. Anyway, thank you for getting back to me!
Joerg wrote: Fri Feb 23, 2024 9:43 pm I am hoping that a future release may include a variable timeout for the max line, up to indefinitely. IMO it should be fairly easy to implement. Anyway, thank you for getting back to me!
Yes, I can see why that would be useful for your requirement. Hopefully Simon may come by and comment.
Best
