I updated SDR Uno to V1.42 1710 on my PC and ran it up with my fully functioning RSP2 that had been running happily under SDR Console 3.1. No problem.
Then updated SDR Console to v3.3. Now the same RSP2 will not start.
SDR Console 3.3 works starts fine with an RTL Dongle.
The RSP2 still works under SDR Uno.
I've reinstalled both (on two machines). I've checked Drivers and API's - all ok.
Any further clues as I've wasted so much time on this today!
Vy 73
Barry G4SJH
V3.3 won't start with RSP2
Re: V3.3 won't start with RSP2
I *assume* you redid the V3 SDRplay definition when you updated SDR Console.
Mike
Mike
Barry,
You must install the latest API from SDRplay and be sure to select a V3 definition.
simon,
Thanks - Selecting a new V3 definition was the key!
Regards
Barry
Regards
Barry
Simon, for future reference. I'm pretty sure the SDRplay API automatically updates with the installation of the latest version of SDRuno.Simon G4ELI wrote: Mon Aug 19, 2024 9:15 am Barry,
Mike
Mike
1) Tell me there is an update available.
2) Tell me why there is an update available.
3) Give me a chance to install the update at my discretion.
I get testy about behind my back updates as I subscribe to the philosophy of "If it ain't broke don't fix it." Are you SURE it goes behind your back and automatically updates the API WHILE IT IS IN USE? (I probably am imaginative enough to make this work. It is, however, an invitation to disaster.)
