Feature Question: User-Defined callsign Makers on the Panadapter
timbrusky
Post by timbrusky »
I am a newer SDR Console user running an SDRplay receiver and have really been enjoying the software.
I like the DX Cluster feature that displays callsigns on the panadapter. I was wondering if SDR Console currently has a way to create user-defined callsign or frequency markers for friends, local operators, favorite nets, or club frequencies.
For example, I would like to create my own entries such as:
● KC9MQE Paul – 3945 kHz
● K1GMM – 3705 kHz
â—Ź Local club frequencies
â—Ź Favorite AM frequencies and nets
Ideally, these would appear as labels or markers on the panadapter, similar to DX Cluster spots, but based on my own entries rather than internet-fed spots.
If this can already be done using Memories, Frequency Manager, Bookmarks, or another feature, I would appreciate any guidance.
Thank you for your help.
73,
Tim Brusky, N2TIM
Fond du Lac, Wisconsin
Re: Feature Question: User-Defined callsign Makers on the Panadapter
Post by KA1GJU »
Tim,
Place your frequencies desired into memories, then edit the memory title to what you want (ie call and freq such as "KA1GJU 3928"
Then in the "ribbon bar", toggle the marker to on (hard to see but the three checkmarks and lines are highlighted in blue). By default, memories are marked, but you can press the "Markers" with the down arrow and configure what you want seen on the screen.
Post by Simon G4ELI »
Or,
Ribbon bar, View, Spectrum, Markers?
Post by Max »
Simon G4ELI wrote: Mon Jun 22, 2026 5:46 am Or,
Yes, just add Markers either manually or via a .csv file. They appear on the spectrum exactly as per the DX Cluster spots.
