QO100 beacon signal level
Also known as ADALM-PLUTO.
Re: QO100 beacon signal level
#11
Hmmm, when it's sunny I must sort things out, I suspect the LNB may be on the wrong polarisation but TX isn't as strong as it should be.
M0TGC
#12
Unread post by M0TGC »
Sounds like your dish is not totally aligned.
How does SDRC calculate the SNR?
David M0TGC
#13
Well,
I've been silly busy for the last two years since putting up the dish, but now have time and enthusiasm to get it sorted out.
SNR - Peak signal versus my idea of noise, an average of the lowest 10% of data - or something like that. Very close to what you see on the screen.
df6dbf
#14
Unread post by df6dbf »
I receive the PSK Beacon with -73dBm with 80cm Offset Dish, Bullseye LNB and PlutoSDR.
Had aligned the Gain of the PlutoSDR with a -73dBm Signal on 739,750MHz from my Stabilock4040 Testset.
So the readout on the SDR-Console is comparable.
73s Holger, DF6DBF
