Please help me
Please help me
Dear Simon, I am glad to welcome you!! Please help me. It is not possible to configure the console to display the 10GHz frequency for normal QO-100 reception, with the normal display on the DSP panel. Settings to display as 99.9 made, settings in the converter made... I can't do it... Help me with some advice. Sincerely, RW3DVG, Alex!
Re: Please help me
tools menu->Options
Upper right. Tick the middle radio button.
That allows the digits to display. It does nothing about conversion. See your posting over in Pluto for a suggestion for posting images to help us help you.
At a hint use the full editor and preview what you have posted and (sigh) annoy the system enough that it will finally post your image(s).
Re: Please help me
See https://www.sdr-radio.com/EsHail-2#ConsoleConfigurationOberon wrote: Thu May 13, 2021 6:47 pm Dear Simon, I am glad to welcome you!! Please help me. It is not possible to configure the console to display the 10GHz frequency for normal QO-100 reception, with the normal display on the DSP panel. Settings to display as 99.9 made, settings in the converter made... I can't do it... Help me with some advice. Sincerely, RW3DVG, Alex!
Re: Please help me
".....See https://www.sdr-radio.com/EsHail-2#ConsoleConfiguration......."
Thank you for your reply!! I've done it all, but it doesn't work out for me. In the attachment is a screenshot from my console. The color indicates that the converter is enabled with the required spacing... What am I doing wrong??
Re: Please help me
Not sure if it's related (probably not), but you are running very outdated version of SDR Console. Current is 3.0.27:
Re: Please help me
Did not realise you had two post topics on the go. I see you are now sorted, but I'd still update to latest 3.0.27.
Re: Please help me
Thank you all so much for helping me solve my problem!! Yes, everything works fine, from the moment I dialed the 10GHz frequency on the console panel!! Once again, thank you all so much for your help!!!
