Error Creating Omnirig instance
N2KI
Unread post by N2KI »
Can someone help me fix this issue? I have Omnirig v1.20 and version 2.1.0.0 installed in two different areas of my system
Thanks for your help.
Anthony - N2KI
Re: Error Creating Omnirig instance
2.0 has a problem with a lot of guy's (not only with SDRconsole), including me.
I have deinstalled v2 completely and reinstalled v1.19 wich works ok.
N2KI
I have done the same thing here, but the error persists. Is there a specific path that Console is looking for as to where Omnirig is expected to be installed? Mine installed at C:\Program Files (x86)\Afreet\OmniRig
Anthony - N2KI
N2KI
Here is my error log if anyone can assess whats going wrong. Thanks!
19:24:17.499@OmniRig: initialising...
19:24:17.499@OmniRig: connecting to existing instance
19:24:17.503@OmniRig: failed
19:24:17.503@OmniRig: creating instance (Flags = CLSCTX_LOCAL_SERVER)
19:24:17.516@Error creating OmniRig instance (Flags = CLSCTX_LOCAL_SERVER) - Error Code 0x800702E4, possibly 'Too many posts were made to a semaphore. '.
19:24:17.516@OmniRig: creating instance (Flags = CLSCTX_ALL)
19:24:17.525@Error creating OmniRig instance (Flags = CLSCTX_ALL) - Error Code 0x800702E4, possibly 'The parameter is incorrect. '.
19:24:17.525@OmniRig: creating instance (Flags = CLSCTX_LOCAL_SERVER | REGCLS_MULTIPLEUSE)
19:24:17.533@Error creating OmniRig instance (Flags = CLSCTX_LOCAL_SERVER | REGCLS_MULTIPLEUSE) - Error Code 0x800702E4, possibly 'The parameter is incorrect. '.
19:24:17.533@OmniRig: creating instance (Flags = CLSCTX_ALL | REGCLS_MULTIPLEUSE)
19:24:17.542@Error creating OmniRig instance (Flags = CLSCTX_ALL | REGCLS_MULTIPLEUSE) - Error Code 0x800702E4, possibly 'The parameter is incorrect. '.
Anthony - N2KI
Hi, this is what i did,
Look in the Windows list of "installed programs" if there are more Omni-Rig versions installed. Uninstall them all.
Than delete the map C:\Program Files (x86)\Afreet\OmniRig
I don't know if you dare to edit the registry but at this point i deleted all keys in the registry that where related to OmniRig.
After this i did a reg clean up with CCleaner and Auslogics Reg Cleaner.
Reboot your PC and install OmniRig 1.19 again. Or 1.20 wich is the most current Afreet download.
N2KI
I would do that but I have no other issues with other softwares accessing and running Omnirig.
Anthony - N2KI
Do as you like but please read this warning, SDRuno has problems to with the unofficial version 2 and higher. And i can confirm that it will give problems, also in combination with the official versions when you install both. https://www.sdrplay.com/sdruno/
N2KI
Interesting. Everywhere it says v1.19 but DX Atlas has only v1.20. Where is v1.19?
Anthony - N2KI
1.19 is attached in a zip (100% free of virusus)
btw i didn't test 1.20 yet and that one could be good.
The problems start with v2.0 but as you can see these are not coming from the official Afreet website.
OmniRig 1.19.zip
(776.69 KiB) Downloaded 298 times
