Can someone help me fix this issue? I have Omnirig v1.20 and version 2.1.0.0 installed in two different areas of my system
Thanks for your help.
Error Creating Omnirig instance
Re: Error Creating Omnirig instance
2.0 has a problem with a lot of guy's (not only with SDRconsole), including me.
I have deinstalled v2 completely and reinstalled v1.19 wich works ok.
I have done the same thing here, but the error persists. Is there a specific path that Console is looking for as to where Omnirig is expected to be installed? Mine installed at C:\Program Files (x86)\Afreet\OmniRig
Anthony - N2KI
Here is my error log if anyone can assess whats going wrong. Thanks!
19:24:17.499@OmniRig: initialising...
19:24:17.499@OmniRig: connecting to existing instance
19:24:17.503@OmniRig: failed
19:24:17.503@OmniRig: creating instance (Flags = CLSCTX_LOCAL_SERVER)
19:24:17.516@Error creating OmniRig instance (Flags = CLSCTX_LOCAL_SERVER) - Error Code 0x800702E4, possibly 'Too many posts were made to a semaphore. '.
19:24:17.516@OmniRig: creating instance (Flags = CLSCTX_ALL)
19:24:17.525@Error creating OmniRig instance (Flags = CLSCTX_ALL) - Error Code 0x800702E4, possibly 'The parameter is incorrect. '.
19:24:17.525@OmniRig: creating instance (Flags = CLSCTX_LOCAL_SERVER | REGCLS_MULTIPLEUSE)
19:24:17.533@Error creating OmniRig instance (Flags = CLSCTX_LOCAL_SERVER | REGCLS_MULTIPLEUSE) - Error Code 0x800702E4, possibly 'The parameter is incorrect. '.
19:24:17.533@OmniRig: creating instance (Flags = CLSCTX_ALL | REGCLS_MULTIPLEUSE)
19:24:17.542@Error creating OmniRig instance (Flags = CLSCTX_ALL | REGCLS_MULTIPLEUSE) - Error Code 0x800702E4, possibly 'The parameter is incorrect. '.
Anthony - N2KI
Hi, this is what i did,
Look in the Windows list of "installed programs" if there are more Omni-Rig versions installed. Uninstall them all.
Than delete the map C:\Program Files (x86)\Afreet\OmniRig
I don't know if you dare to edit the registry but at this point i deleted all keys in the registry that where related to OmniRig.
After this i did a reg clean up with CCleaner and Auslogics Reg Cleaner.
Reboot your PC and install OmniRig 1.19 again. Or 1.20 wich is the most current Afreet download.
I would do that but I have no other issues with other softwares accessing and running Omnirig.
Anthony - N2KI
Do as you like but please read this warning, SDRuno has problems to with the unofficial version 2 and higher. And i can confirm that it will give problems, also in combination with the official versions when you install both. https://www.sdrplay.com/sdruno/
Interesting. Everywhere it says v1.19 but DX Atlas has only v1.20. Where is v1.19?
Anthony - N2KI
1.19 is attached in a zip (100% free of virusus)
btw i didn't test 1.20 yet and that one could be good.
The problems start with v2.0 but as you can see these are not coming from the official Afreet website.
- OmniRig 1.19.zip
- (776.69 KiB) Downloaded 293 times
