Simons world map wont run
g4eyt
Unread post by g4eyt »
Hello all
I would be grateful for any pointers please. After several downloads I cannot get Simons world map to run. I get the initial screen with no map for a few seconds then it disappears.
I have a windows 10 machine which has all the latest updates downloaded.
SDR console V3 runs well with my Hermes lite 2 (thanks Simon!)
I hope the screenshots help.
Thanks very much!
Best wishes
Colin
James_VA3JPX
Re: Simons world map wont run
Unread post by James_VA3JPX »
Hey Folks,
I too am having the same problem, with a slight difference in behavior.
I am running Windows10. The program installs with no problems. But when I run the program, it runs for about 2 seconds, then disappears. Task manager doesn't even show it running.
My system:
Dell Duo CPU E8400, 3Ghz
6 GB Ram
Win10 Home 21H2, OS Build: 19044.1526
Experience: Windows Features Experience Pack 120.2212.4170.0
Windows Event Viewer report for when the app crashes:
Faulting application name: SimonsWorldMap.exe, version: 1.0.0.1, time stamp: 0x61e7121c
Faulting module name: d2d1.dll, version: 10.0.19041.546, time stamp: 0xdf04746a
Exception code: 0xc0000005
Fault offset: 0x000000000002d767
Faulting process id: 0xc78
Faulting application start time: 0x01d831730941b0e4
Faulting application path: C:\Program Files\Simon's World Map\SimonsWorldMap.exe
Faulting module path: C:\WINDOWS\SYSTEM32\d2d1.dll
Report Id: f78e0386-f5d9-46cf-9478-3523f8d70fa2
Faulting package full name:
Faulting package-relative application ID:
Any advice on how I should proceed in troubleshooting the issue?
Thank you,
James
VA3JPX
From Control Panel select System and show me this.
Also I'll add BugTrap so you can forward crash dumps.
This kit https://www.dropbox.com/s/6dhaddktjqvae ... 6.exe?dl=0 has bugtrap so should create a crash dump when it has a problem. More testing tomorrow...
James_VA3JPX
Simon G4ELI wrote: Sun Mar 06, 2022 7:46 pm From Control Panel select System and show me this.
Here you go.
Dump info sent in previous reply.
James
Thanks, I also use Core2DUO - cracking CPUs if a bit power-hungry.
Please use this kit https://www.dropbox.com/s/3vjruh21w859o ... 7.exe?dl=0 I made an error and couldn't analyse the previous kit. With luck I'll be able to analyse this file.
