Receiver Changing Frequency - Feature or Bug
Re: Receiver Changing Frequency - Feature or Bug
OK, thanks for reporting this, fixed it this morning. The video really helped.
Watch receiver #2 it will change to the frequency of receiver #4 as I use my mouse to select different receivers.
Simon, did your fix for this get in v3.0.25? I just checked and it is still happening.
In the video link below you will see that receiver #2 changes to the frequency of receiver #4 as I use the mouse to select receivers.
As always thanks for the great software....
Simon, any update on this? As described in post above I still have this issue with 3.0.25. Should this have been fixed or will the fix be in 3.1?
Thanks...
Thanks...
Hi,ka6fub wrote: Tue Oct 06, 2020 3:34 am Simon, any update on this? As described in post above I still have this issue with 3.0.25. Should this have been fixed or will the fix be in 3.1?
Thanks...
I just found the Bookmarks option in this forum so have this bookmarked. I'll try and fix it today with any luck.
Thanks Simon...
Simon, just checked in v3.0.26 and still doing the same thing. Is this still on the list of things to fix? I did not see any mention that it one of the items fixed in 3.0.26's release notes.
Thank you...
Thank you...
Forgot to mention to watch as receiver 3 changes to receiver 4 frequency as I select the receivers.
Simon, back into fire season here and using my multi frequency configuration again. Still having the problem with receivers changing frequency as I use mouse to select different receivers as seen in the video I send last year. Using ver 3.0.27 build 2190.
Will this ever get resolved?
Thank you...
Thank you...
I'll attack it tomorrow first thing.ka6fub wrote: Sun Jun 27, 2021 5:29 pm Simon, back into fire season here and using my multi frequency configuration again. Still having the problem with receivers changing frequency as I use mouse to select different receivers as seen in the video I send last year. Using ver 3.0.27 build 2190.
Thank you...
