SDR Console - Does not startup
VMARS
Unread post by VMARS »
I've been using SDR Console for some years and taking the upgrades as they come in 32 bit. I operate Win10.
Recently my SDR Console simply will not startup correctly. I've attached a screenshot.
The "Select Radio" screen does not seem to want to pop up.
This even occurs without any USB SDR connection.
Any thoughts please.
Regards,
Martin
VMARS
Re: SDR Console - Does not startup
As an update, I've just completely de-installed, restarted the PC, re-installed and the same occurs with SDR Console taking 29% CPU and 37MB memory (High) No Disk, No Network.
In recent days I've taken a standard MS update for Win10 32 bit. Could this be the issue.
Regards,
Martin
On the downloads page, follow the instructions to reinstall the redistributable packs. Looks like it's stuck either loading the SDR DLLs or somewhere in that area.
Another thing you could do is to run DebugView: https://www.sdr-radio.com/diagnostics#DebugView as it may be spewing out errors.
Just checked on a small 2GB W10 32-bit system - this also hangs, so will sort the problem out.
VMARS
Roger.
Many thanks
Martin
OK,
I was wrong about my system hanging. Suggest you start DebugView, let's see what that shows.
VMARS
Ok Will do.
Martin
VMARS
Attached is the debug file from running debug viewer online, from startup of SDR Console 3.1 on 32 bit Win 10 up until it freezes as already shown.
It doesn't mean an awful lot to me and I can't see anything obvious.
Rgds
Martin
Debug File.LOG
(17.02 KiB) Downloaded 285 times
VMARS
Ive done another debug file and left it a little longer this time. See attached.
Rgds
Martin
M0MGA
Debug 2.LOG
(28.32 KiB) Downloaded 270 times
VMARS
I've ran the re-install of redistributables this morning.
I get an error when I reach C++ 2019 redistributable:
"Error 0x80070666: Cannot install a product when a newer version is installed."
Please see attched log file.
Regards,
Martin
M0MGA
dd_vcredist_x86_20220728081724.log
(4.96 KiB) Downloaded 247 times
