Receiver Changing Frequency - Feature or Bug
Re: Receiver Changing Frequency - Feature or Bug
OK, thanks for reporting this, fixed it this morning. The video really helped.
ka6fub
Unread post by ka6fub »
Watch receiver #2 it will change to the frequency of receiver #4 as I use my mouse to select different receivers.
ka6fub
Simon, did your fix for this get in v3.0.25? I just checked and it is still happening.
In the video link below you will see that receiver #2 changes to the frequency of receiver #4 as I use the mouse to select receivers.
As always thanks for the great software....
ka6fub
Simon, any update on this? As described in post above I still have this issue with 3.0.25. Should this have been fixed or will the fix be in 3.1?
Thanks...
#15
ka6fub wrote: Tue Oct 06, 2020 3:34 am Simon, any update on this? As described in post above I still have this issue with 3.0.25. Should this have been fixed or will the fix be in 3.1?
Thanks...
I just found the Bookmarks option in this forum so have this bookmarked. I'll try and fix it today with any luck.
ka6fub
#16
Thanks Simon...
ka6fub
#17
Simon, just checked in v3.0.26 and still doing the same thing. Is this still on the list of things to fix? I did not see any mention that it one of the items fixed in 3.0.26's release notes.
Thank you...
ka6fub
#18
Forgot to mention to watch as receiver 3 changes to receiver 4 frequency as I select the receivers.
ka6fub
#19
Simon, back into fire season here and using my multi frequency configuration again. Still having the problem with receivers changing frequency as I use mouse to select different receivers as seen in the video I send last year. Using ver 3.0.27 build 2190.
Will this ever get resolved?
Thank you...
#20
ka6fub wrote: Sun Jun 27, 2021 5:29 pm Simon, back into fire season here and using my multi frequency configuration again. Still having the problem with receivers changing frequency as I use mouse to select different receivers as seen in the video I send last year. Using ver 3.0.27 build 2190.
Thank you...
I'll attack it tomorrow first thing.
