MIDI volume control - Beta 3.1 (b2365)
IU4FIR
Unread post by IU4FIR »
Hi, I have encountered a problem using HERCULES DJ CONTROL STARLIGHT as a MIDI controller. (DJ Control
The volume control is not linear but works in jerks, going from level 0 to 65 or 100 with a few mm of rotation on the command, it also happens by configuring the others console command for AF gain control.
Version in use: V3.1 BETA (b2365)
MIDI Control configuration
Re: MIDI volume control - Beta 3.1 (b2365)
https://www.hercules.com/en-us/product/ ... olcompact/
The DJ Control Compact works fine. Some Starlight midi commands are different.
IU4FIR
Issue solved changing the INDEX value in to XML Midi configuration file :P :P :P
</MidiDefn><MidiDefn Enable="1" Item="8" Type="3" Channel="0" Index="3" Value="0" ValueMax="127" Device="DJControl Starlight" Name="Audio Level" Modifiers="">
Here the image of setup:
also the layout of the controller should be useful to someone
Hercules_Starlight_SDRConsole_v3.pdf
(518.34 KiB) Downloaded 290 times
Now works 100%
73 IU4FIR
Nice, many thanks for sharing your solution!
@Jim (G0OFE) can you move this tread to Console Interfacing for easy find in the future? Thx OM
dg9bfc_sigi
Unread post by dg9bfc_sigi »
i would use the two platters for tune fine and coarse
it has sensors ontop the wheels so you can use both wheels with two step sizes
example .. right wheel tune normal and tune fine (100hz and 10hz) and left wheel tune 1 kc and 10 kc
greetz sigi dg9bfc
